I have now tried the SNMP on a Solo2 and still does not work correctly.
What you need to make the server part work is:
libnetsnmp20_svn-r5.0_mipsel.ipk (libary files needed for the binary to run)
net-snmp-mibs_svn-r5.0_mipsel.ipk (mib files)
net-snmp-server_svn-r5.0_mipsel.ipk (server files)
Not needed
net-snmp-client_svn-r5.0_mipsel.ipk (only needed if you like to have the client tools locally)
snmp_init_bh.tgz (not needed since the /etc/init.d/snmpd (snmp start file) is included in net-snmp-server_svn-r5.0_mipsel.ipk)
For some reason I did not get the install to run, so I did install the need files manual, set the correct rights and then run:
/etc/init.d/snmpd start
This then start the SNMPD daemon.
can bee seen by running:
netstat -upan
giving:
udp 0 0 0.0.0.0:161 0.0.0.0:* 21247/snmpd
If I then run from another computer/server:
snmpwalk -v 1 -c public 10.10.10.41 1.3
I still get only this:
iso.3.6.1.2.1.1.1.0 = STRING: "Linux vu-solo2-stue 3.3.8-2.0 #1 SMP Wed May 7 18:49:03 CEST 2014 mips"
iso.3.6.1.2.1.1.2.0 = OID: iso.3
iso.3.6.1.2.1.1.3.0 = Timeticks: (7306) 0:01:13.06
iso.3.6.1.2.1.1.4.0 = STRING: "Root <root@localhost> (configure /etc/snmp/snmpd.local.conf)"
iso.3.6.1.2.1.1.5.0 = STRING: "vu-solo2-stue"
iso.3.6.1.2.1.1.6.0 = STRING: "Unknown (configure /etc/snmp/snmpd.local.conf)"
iso.3.6.1.2.1.1.8.0 = Timeticks: (6) 0:00:00.06
iso.3.6.1.2.1.1.9.1.2.1 = OID: iso.3.6.1.6.3.11.2.3.1.1
iso.3.6.1.2.1.1.9.1.2.2 = OID: iso.3.6.1.6.3.15.2.1.1
iso.3.6.1.2.1.1.9.1.2.3 = OID: iso.3.6.1.6.3.10.3.1.1
iso.3.6.1.2.1.1.9.1.2.4 = OID: iso.3.6.1.6.3.1
iso.3.6.1.2.1.1.9.1.2.5 = OID: iso.3.6.1.2.1.49
iso.3.6.1.2.1.1.9.1.2.6 = OID: iso.3.6.1.2.1.4
iso.3.6.1.2.1.1.9.1.2.7 = OID: iso.3.6.1.2.1.50
iso.3.6.1.2.1.1.9.1.2.8 = OID: iso.3.6.1.6.3.16.2.2.1
iso.3.6.1.2.1.1.9.1.3.1 = STRING: "The MIB for Message Processing and Dispatching."
iso.3.6.1.2.1.1.9.1.3.2 = STRING: "The MIB for Message Processing and Dispatching."
iso.3.6.1.2.1.1.9.1.3.3 = STRING: "The SNMP Management Architecture MIB."
iso.3.6.1.2.1.1.9.1.3.4 = STRING: "The MIB module for SNMPv2 entities"
iso.3.6.1.2.1.1.9.1.3.5 = STRING: "The MIB module for managing TCP implementations"
iso.3.6.1.2.1.1.9.1.3.6 = STRING: "The MIB module for managing IP and ICMP implementations"
iso.3.6.1.2.1.1.9.1.3.7 = STRING: "The MIB module for managing UDP implementations"
iso.3.6.1.2.1.1.9.1.3.8 = STRING: "View-based Access Control Model for SNMP."
iso.3.6.1.2.1.1.9.1.4.1 = Timeticks: (6) 0:00:00.06
iso.3.6.1.2.1.1.9.1.4.2 = Timeticks: (6) 0:00:00.06
iso.3.6.1.2.1.1.9.1.4.3 = Timeticks: (6) 0:00:00.06
iso.3.6.1.2.1.1.9.1.4.4 = Timeticks: (6) 0:00:00.06
iso.3.6.1.2.1.1.9.1.4.5 = Timeticks: (6) 0:00:00.06
iso.3.6.1.2.1.1.9.1.4.6 = Timeticks: (6) 0:00:00.06
iso.3.6.1.2.1.1.9.1.4.7 = Timeticks: (6) 0:00:00.06
iso.3.6.1.2.1.1.9.1.4.8 = Timeticks: (6) 0:00:00.06
End of MIB
What I miss is the CPU/Memory/interface info like this:
Load
1 minute Load: .1.3.6.1.4.1.2021.10.1.3.1
5 minute Load: .1.3.6.1.4.1.2021.10.1.3.2
15 minute Load: .1.3.6.1.4.1.2021.10.1.3.3
CPU
percentage of user CPU time: .1.3.6.1.4.1.2021.11.9.0
raw user cpu time: .1.3.6.1.4.1.2021.11.50.0
percentages of system CPU time: .1.3.6.1.4.1.2021.11.10.0
raw system cpu time: .1.3.6.1.4.1.2021.11.52.0
percentages of idle CPU time: .1.3.6.1.4.1.2021.11.11.0
raw idle cpu time: .1.3.6.1.4.1.2021.11.53.0
raw nice cpu time: .1.3.6.1.4.1.2021.11.51.0
Memory Statistics
Total Swap Size: .1.3.6.1.4.1.2021.4.3.0
Available Swap Space: .1.3.6.1.4.1.2021.4.4.0
Total RAM in machine: .1.3.6.1.4.1.2021.4.5.0
Total RAM used: .1.3.6.1.4.1.2021.4.6.0
Total RAM Free: .1.3.6.1.4.1.2021.4.11.0
Total RAM Shared: .1.3.6.1.4.1.2021.4.13.0
Total RAM Buffered: .1.3.6.1.4.1.2021.4.14.0
Total Cached Memory: .1.3.6.1.4.1.2021.4.15.0
Any help with this would be nice.
My SNMP tool hangs (or uses long time) when trying to list what resources to monitor from my VU+ Solo
