Ghost Protocol
Hotbird 13 channels worked fine, installed 2.1.7 and updated Vhannibal channel list and now none of them work and SNR 0%? Help appreciated, do I need to update the FPGA, if so how do I do that?
Thanks.
Thanks.
Have you configured your tuners properly?
try doing a manual scan, of a known, active, FTA, transponder, on 13E, and see if you get a signal.
Flashed the box again and checked tuner config, just done a service scan on Hotbird 13 and only found 12 services on one frequency, nothing on the other frequencies, would this confirm that the LNB is working ok?
View attachment 22762 View attachment 22763
