Solo 1 recording problem
Jules
Hi Guys, I have a wierd problem if you can help me please?
I have managed to add an external usb HDD to my solo.
It will play recordings and do timeshift, but when I try to record I just get the green reset screen every time.
I know there is a setting I must have missed somewhere.
Thanks.
Regards,
Jules.
Thanks. This is where I may have the problem. There seems to be no HDD folder in my system.
I can record with timer no problem, it is only instant record that won't work, unit just crashes.
Have you set up recording paths? and set up a HDD mountpoint.
hi, try turning off permanent timeshift and try instant record again. that was the problem for me.
hope it works for u;-)
