Solo 2 OSD offset
zedster4
Hi, My OSD is offset to the left so I can only see the end on each menu which makes life really hard for me a beginner.
I read the following statement which explains how to fix the issue but I cant find the OSD menu as described. Please can anybody help?
First exit out of the channel list screen by pressing exit on the remote. You should see the Vu loading screen.
To set the OSD go to> menu > setup > OSD > OSD SETUP
Here you can use the up / down buttons to select each option and the left / right buttons to adjust the setting themselves. Once you are happy that your OSD picture is setup press green to save these settings.
I should mention I dont see the Vu loading screen I only see the channel I'm watching. Am I missing some other button press first?
I'm running BH 3.0.2
Bazza
Bazza
For Black Hole image you have to use UI position setup plugin.
Green button >> UI position setup
If you not have UI position setup in plugin list (green button)
You have to enable plugin in
blue button>>blue>>Black Hole Speed Up
Of course it is possible that your TV has no good setup, check in the TV.
