Solo 2 remote frequency
zedster4
Hi, guys
Does anybody know what frequency the remote uses for a solo 2?
I've just brought a new video sender (All in one SV1760) and I cant get the remote to work with it :-(
The FAQ says "The IR extender function works with all remotes which operate with 30-60kHz frequency, please check your original remote to see if it is compatibile."
My old sender (Nikkai A96JJ) works fine with the remote but the picture and sound is crap so I decided to invest in a new one.
The new SV1760 works a treat and the picture and sound is brilliant but I cant control the box now unless using WEB control which is not ideal.
Bazza
Thanks, guys,
I found out what the problem is but I'm still thinking about the solution. It would appear that the IR transmitter needs to be quite a distance from the receiver to work correctly, a lot further than my current one. The problem is its so far it wont locate on my stand Grrrrrrrrrrr. Maybe better placing directly in front of the IR receiver on the Vu may work. Do you know where the location is?
Bazza
Sorry but that made me laugh. I should have been a bit more specific when asking where it is. Do you know if its near the left or right of the display
