Thank you for your help, I will take a look at my lnb beacuse as you mentioned I cant find any tuner when I´m trying to make a search,so it´s quite possible that my problem not is the reciever,instead the sat-disc or something there between.
Can you please post your satellite set up, fixed dish, single LNB, several LNB's, with Diseqc switch, motorized dish, satellites you can receive, and your tuner settings.
We might be able to spot something you've missed.
