Solo 2 - VFD HELP
ragbob
Hello
I'm sure my VDF use to display what channel was showing. Now it only displays the last menu item used, such as Menu or System etc..
Does anyone know how to resolve this or is there an addon that I can use?
Thanks
Hello
Thanks
VFD is driven by skin. Reinstall your BH compatible skin. If you used to use default skin, reflash.
Im sorry Paulino
It is not correct
VFD is not coded in the BH skin coding.Not in my skins only standby window in some skins.
If coded VFD is coded in skin_user.xml.
Hello
Thanks
I think you have download LCD skin from our server for VU+ Ultimo
or you using skin that is not coded by the BH team skin coders.
Matrix10, you are absolutely right, I didn'trealise that I am using a Duo skin "BlueNight2_P".
I'll live with it, skin is awesome.
Thanks to all for replies.
