Solo 4K+DVB-C Problem?
veskop
Hi,I have brand new Solo4K with new DVB-C/T tuner (TT2L08) whitch I try to use for my cabel provider here in Bulgaria.The problem is,that it doesnt work.I can see tuner in Settings,I can see signal stretch,when I connect my cable,but screen keeps black?Receiver show error :No data on transponder(Tineout reading PAT).I tryed all types of scan-manual,full,cable scanbut NOTHING,it say No channels found or SCan Failed (on cable scan)Allso tryed all possible image (up-to-date) but have the same problem.I put my channel list from my GB Quad,where everithing was OK but result is the same-black screen!Cable is OK,I revert my GB Quad and everything is OK,when I put Solo 4K,there is no picture.Allso replace original file cables.xml with my from Gigablue-again nothing!Any advise?Thanks!
PS.Now receiver is with last VTI image,but I tryed all-ATV,PLI,BH,PBNIGMA....
I saw it,but my provider is not on list.I tryed all type of scan,nut nothing....Tomorow I will receive new box from seller ,will see if it work.
