You seem to have ruled out problems with your set up, including LNB, dish, cabling and television, by trying other receivers, which only leaves a problem with your VU+ Solo SE.
Can you try your Solo SE on another dish/cable, if only a friend/relatives system? To see if it the receiver works.
