Hello,
I want to buy an Enigma 2 machine but I don't know which one to choose between two VU+ products: Solo SE v2 or Solo2.
Do you think it is worth spending about 40$ more for Solo2 instead of the Solo SE v2?
Looking at the technical characteristics, here are the differences:
- the Solo SE v2 has an external IR receiver,
- the Solo SE v2 has twice of nand flash memory (512 MB against 256 of the Solo2)
- the Solo SE v2 I think is much newer of the Solo2,
- in the Solo2 you can add an internal hard disk;
- the Solo2 has a VFD display and a front USB.
Display, internal HDD and external IR receiver are not important but may be useful, but what about the half "flash memory"?
I'm not an expert: what is Nand Flash Memory? It may be a limitation to have 256MB instead of 512MB? What changes?
Thank you in advance.
