SOLO2 and diseqc 1.2 and DIPLEXER -perhaps
E_lite
Hi, i had a terrible iissue today,, SOLO2 not work with diseqc motor.. and diplexer between. and its 100% confirmed issue, becouse i must put an old DUO instead of great solo2.. also the other GM....(whatever) and dream500 works in same place.
the same solo2 also works in other place whe no diplexer in system..
not even the manual 1.2 settnigs helped.. sipmel cannot find the position-- always can move back to 0 (astra19) but novhere else and back..
Guys, just write this becouse of the warning to others who faced with this problem.. it pitty, and i cannot explain, not even solve the thing--
ohh and some small thing: i upload a PLI3.0 last at one moment-- it worked good for a 10 minutes, but when i restart first time at main switch at the back.. it stops moving... somebody can tell why? o left the duo there so i cannot change or test anything from now, bit maybe somebody can tell whats happend?
used the last swf- also went back to 207 -same result- no swf problem for sure.
will post it somewhere else too..
T.
