Solo2 and HDMI-CEC use
wave1975
Hi!
I have
1) LG LM670
2) Pioneer VSX-921 A/V
3) Solo2 with blackhole
It is impossible to make it work (i.e pass through from solo2 to the tv set when the av is switched off).
I am using the plugin but it is not working.. In fact, when pioneer is off, even the tv set doesn't play the sound for the tv set speakers.. at all..
I am gonna check the hdmi cable (i have only one -the original that came with solo2- connecting solo2 with the av receiver and then only another one from the "out" of the receiver to HDMI1 (ARC) of the tv set.
Any ideas???
regards
Hi and happy new year
1) Sony 40w4500
2) solo 2 with BH
HDMI-CEC plugin works like a Rolex.
did you check the HDMI cable directly Solo2 to Tv ?
1) if it works, the problem is A/V (surf with google), or second HDMI cable has issue.
2) if doesn't work , buy a new hdmi-cec cable , i bought my cable on amazon for less then 10 euro
regards from spread country
