Solo2 crush
WILgu
Hello All,
I have strange difficulties with my Solo2.
Box looks to be genuie (checked with plugin available in BH 2.1.5 - passed with success).
No HDD or other external devices.
I have bought box 4-5 months ago and flash with BH image.
All worked fine until end of September.
Beacuse of changes done by providers I had to upload new setting to the box.
And since that time I have a lot of difficulties with proper using of my box.
I am able to flash the box using usb. All is OK.
After setup configuration, innstall cams (reboot box), upload settings all works fine - for a couple of hours.
After the box is off (not deep) there is nothing. Show standard skin and so on, however, cam not working.
In case of trying to restart, green crash screen appear and restart, and green screen and all the time the same.
The only way is switch off using back switch.
After switch on BH logo appear, then black screen and that's all. Starting on the box and nothing more.
Box need to be re-falshed.
What I found. Strange thing. After 1 hour of proper work I am checking status of memory (blue --> yellow) and see 0% of use for everything (flash, ram, etc.)
In case of I do not off box (in any way) or change the channel or try to start any plugin all works fine (on this 1 channel using cam).
When I try to do any change - box is crashing.
BH logo and starting all the time.
The only way is re-flash box. Re-falshing is possible every time without problems, so far.
Could you please advise what could be wrong?
I have no idea what can I do to solve it.
Yesterday I tried to use original vu image and box work fine for 1 hour (but I cannot use cam to share emc with my second box - server).
I tried flash box with BH 2.1.5 and everything was OK for 1 hour. After 1 hour 0% flash in use, 0% ram in use... I did not off the box or change anything and today morning works OK, but I am affraid that in case of any changes (even changing channel) the box will crash.
If you need more info plase let me know.
It is really frustrated, because I have to re-flash my box every time I would like watch tv.
Hello All,
Probably hw fault.
You will be banned. No CAM software welcome here.
