Hi all
I have Vu+ Solo2 running blackhole 2.0.1 rev A
Every hour or so my gets blackhole spinner then i loose internet connection
does anyone what may be causing this
Hi all
Try to connect first your box
and then rest on your router.
You can also try to change port for your BOX.
USE DHCP.
Or try first this:
Another option is to give box a fixed IP address
and not DHCP.
But the address must be in the IP adress range of your router.
Restart the box and test
