solo2/duo2 dlna issue
denon54
Hi,
i don't know if i am the only one havong that problem, the thing is that i noticed for solo2 that in previous version of BH firmware , for example in BH2.0.2 you could use veryeasily dlna .
Imean with that version on my Panasonic and Samsung tv i could see folders of my receiver and also favourite folders then all chaneel Inside these folders , then you chose the channe you want to Watch and eveything went fine.
That was in previous BH firmware, now that i update to the latest one 2.0.8 it is not possible anymore , i can stil see favourite channel but the nothing happen when you select the channel.
Hope it will be solved in the future
Of course i did , that's also what i did when i was in BH2.0.2, but now with newer version of BH doesn't work anymore,
it is really a pitty because i bought that vu+duo specially for that, hope that it will be fixed in further BH firmware.
