Solo2 Feed Hunting?
dannyllama
Now that my motorised system is working well, I am interested in feed hunting. However I see that most of the feeds are in MPEG2 or MPEG4 (4:2:0 / 4:2:2). Is the Solo2 capable of handling the different feeds? If so, how to find them (Blindscan)?
Thanks in advance.
Thanks in advance.
4:2:2 it's not supported by CPU.
4:2:0 are just normal, you might be able to open 4:2:2 using your PC.
If you want to see a feed you can view the Ashes test, on 24.5W, depending on your location, and size of dish.
Try moving your dish, to 24.5W, then manually scanning in 11589 H 7120 DVB-S2 8PSK 3/4
