Solo2 Question
coopernokia
Hey,
I've a quick question about my Vu+Solo2 Box, Every night at 22:10 my box does something strange... If I'm watching anything on a channel the screen will go blank and I wont get a picture until I change channel (the box is still responsive and appears normal apart from no television program), also if I'm streaming anything it will stop working at the same time. Sorry if this has been posted before but as I don't know how to describe it properly I cant search for it to pre check.
What is this and why does it do it?
Can i stop it doing it or even change the time that it does it?
I'm running the hyperspace bh image.
Thanks in advance for any help,its greatly appreciated
Hey,
Take a look into your cron manager if there something setted up around the time you write
Theres nothing setup in my Cron Manager (looking at it through the menu,it gives me the option to add or delete but doesn't actually show anything)
Yummer you legend, I was using the Hip Hop Epg Stream Channel which refresh's at 22:10 every day,why it has the knock on effect it does; I don't know but at least I am now able to change the time to a time when I'm not watching anything.
Thanks again for all the suggestions :)
