Solo2 streaming iptv to box is slow
Pal Ryvaenge
Hi, streaming from box to pc/phone is always good, both SD/HD.
Tried earler to stream channels from Zero to Solo2 and the other way, SD good, but HD laggy.
Now trying IPTV, HD channels above 5-6 Mbs is having problems after a short time.
This box has Gigabit Lan, my network is Gigabit, and all is cabled.
Is the hardware of this box the problem?
Solo2 - 3.0.2F
Internet 40/40 fiber optics
Speedtest from Kodi (speedtest.net) 37.51 / 36.13
Hi, nothing to do with the network. I guess the hardware of theese boxes is not strong enough to receive a stream with above about 5Mb/s. I bought a cheap Android TV box with Kodi instead for that purpose.
@Pal Ryvaenge, Vu+ boxes primary purpose is sat TV. But they work perfect with IPTV, or terestrial too. Check your settings, or IPTV providers stream.
Another question if anyone can answer.
IPTV channels with audio codec "codec A52 Audio (aka AC3) (a52) 3F2R/LFE" does not show any audio tracks and is therefor without sound.
But this is the same codec that the channel is broadcasting through satellite, but then works? Any clues?
Have you tried the IPTV plugin with FFmpeg and ext3player?.....Seems to run perfect on Solo2.
