Solo2 stuck on 'VU+ SOLO2' and no picture on screen
csdance
Hi. My VU+ Solo2 defaulted itself overnight so I done a reboot and it died. At this point, I flashed it with the latest Black Hole from this stie, and when starting up, I get the Black Hole image on screen then the box says "VU+ SOLO2" and does nothing else, it does not react when putting into standby and nothing is on screen, I have forced power-out to reboot then flash another image to the box but the same thing happens. Any ideas? Thanks.
Okay, what image would you recommend, I might be doing something wrong. I have used Black Hole (and if I had a choice, I would like to load OpenVix) but what image would you recommend and can you please help me with a download link so I know I'm working with something compatible with my box as I'm a newbie to this and not 100% sure what I'm doing... I can try that and if that doesn't work, I can send back for repair
If the box is under warranty, to the reseller.
If it's outside warranty period, ask reseller of your area for a repair.
After reading your posts, I'm convinced your box is a clone.
I don't think it's in warranty... but I have checked as per the check link above, this box is 100% genuine
