Solo2 Twin Tuner setup
djxean
Hello Community,
Just a bit confused what setup to do. i have 13e, 19.2 and 28.2e and i would like is when i record on ex.13e while watching 19.2e or 28.2e? or some transponder on 13e.
each 3 Sat. LNB has only 1 output each. and im using 4x1 Diseqc connected to (LNB A Solo2) BH.
newbie on this of course i dont want to make any risk doing it because i dont wanna messup with an expensive stb..
hope some pro's help me out.. thanks!!
Best Regards
You must have one separate cable for each tuner.
You must connect a second cable, with its own diseqc, and to a available output on your lnb. So you need new twin or quad lnb and an extra diseqc.
