I have recently installed a 1TB internal SATA III in Solo2. Could you please let me know how can I set up daily (weekdays) recording for a particular program?
I can see EPG has Add timer option. However, how this is linked to recording? When I press red recording button (at the bottom of the remote) it only allows to record current program.
You need the auto timer plugin, think its in feeds section.
Pretty simple but ask if you get stuck.
I use it with cooltvguide as you can set a shortcut in cooltvguide to make it easier.
Many thanks for your help. I have installed both plugins cooltvguide (V6.4.0) and auto timer. CTG is quite easy to set up recording. I noticed CTG has timer option, what is advantage of auto timer here? Cheers!
