Hi all,
I have a monoblock on my dish which allows me to hit Hotbird 13E and Astra 19.2E (I am in Spain right now). It just has one cable coming out of it, and down into my VU+ box. I've had access to channels on both satellites for a year or so now without any issues, but suddenly I have stopped getting anything from Astra 19.2. When I do a manual scan of Hotbird, it finds everything. When I do the same for Astra, it finds 26 channels only!
I don't think I've changed anything, but maybe I am missing something somewhere. Hotbird seems ok, but can be a bit 'stuttery' at times. I am not 100% clear on what I should be seeing in the "Satfinder" menu, but this is what I get ...
Hotbird 13.0E:
The indicator bars will only show up when it's set to "Predefined Transponder", and with that my results are:
SNR: 50%
AGC: 65%
BER: 0%
LOCK: Ticked
Astra 19.2E:
The indicator bars will only show up when it's set to "Manual Transponder" in this instance:
SNR: Bounces up and down like crazy and won't settle
AGC: Same as above. Seems to go from 0 to 65% every second
BER: 0%
LOCK: Constantly goes on and off
If I leave the Satfinder menu, and go back later, Astra 19.2E will usually have locked on, but the SNR and AGC are similar to the Hotbird ones (50% and 65% respectively).
It seems like Astra just can't get a lock anymore for some reason, and the overall SNR readings seem pretty low. I am not 100% sure, but I am guessing they should be higher than that? I am sure it was around 90% in the past. I haven't gone up on the roof to check the satellite itself because it's not very accessible. I can't think of any reason for that to suddenly go wrong though as no one goes up there and we don't really have any extreme weather.
Can anyone think of anything else that might be causing this suddenly? I'd rather make sure I've done everything I can to fix it at the box-level before I have to go check on the roof. Even if I do go up there, I am guessing I would need professional help to adjust anything accurately?
Here are the rest of my relevant box settings:
Model: VU+ Solo SE
Image: BlackHole 2.1.6 (.1)
Tuner Configuration: Vuplus DVB-S NIM(AVL6211) (DVB-S2)
DISEqc A/B (Sats: 13E Eutelsat, 19.2E Astra)
Sorry for the long post, just want to get as much info in here as possible to help troubleshoot. I am not an expert in this stuff (although have some experience), hence posting in the newbies section
Thanks very much,
Ori
Hotbird 13.0E:
SNR: 50%
AGC: 65%
BER: 0%
LOCK: Ticked
Astra 19.2E:
BER: 0%
Model: VU+ Solo SE
Thanks very much,
Ori
