Solo2 Some questions before buying
pim
Hello
I have a 5 years old DM800 and I'd like to change it for the vu+ solo2 which is faster and newer
But before buying I'd like to be sure that this device handles some features I really need :
- Can I play the sound of AC3+ channels (dolby digital PLUS) such as french channels on Atlantic bird (5°W) ?
- Can I create an IPTV bouquet list (without having to use a 3rd party plugin) ?
- Can I play mms IPTV streams ?
Hello
1) Yes. DD+ (Dolby Digital Plus) is currently supported
2) I don't know
3) No. MMS streams aren't currently supported by Vu+ boxes.
2)
If you are talking about things like below then I guess that the answer is yes.
First entry TV, second Radio the later geolocked I think.
#NAME IP_TV
#SERVICE 4097:0:0:0:0:0:0:0:0:0:rtmp%3a//82.201.102.111%3a80/live/_definst_/tv538:538 TV OK
#DESCRIPTION 538 TV OK
#SERVICE 4097:0:2:0:0:0:0:0:0:0:rtsp%3a//mobil-live.sr.se/mobilradio/kanaler/p4gavleborg-aac-32:Radio Gävleborg P4 OK 3gp rtsp low
#DESCRIPTION Radio Gävleborg P4 OK 3gp rtsp low
Yes that's what I'm thinking about. I mean like on my dreambox I click on the blue button and then I have the list of all the tv groups I've created. I was wondering if there is an option to add a group with ip streaming channels. But I think I have my answer now :)
The only bad thing is that the box doesn't support mms. Is this planned for later ? I know it isn't sooo important but as the DM800SE supports mms streams I wonder why vu+ solo 2 can't as it is much more powerful
Ask directly Vu+ about that.
