Hi,
i've got my SoloSE today, i'm still little by little getting used to it...
- In the A/V settings, i've saw an "autoresolution" options, should i turn it on or off? My tv is at the moment a "low quality" full HD, should i set the exit at 1080p or 1080i? Or put autoresolution?
- In the "all channel list" there is a way to search by letter? Or i've to start at the start and move with the arrows page by page? I can't find how to skip to a specific letter (just pressing the number doesn't work)
- I've set the remote to turn on and off my tv, but i would like the mute button to mute the VU e not the tv (i don't use the tv audio but 5.1+denon avr), is this possible?
- i get only 4 packages on the cross epg, i've to go on some channel to find more? Can i download other kind of EPG from the BH directly? Now i see only the actual program and next, i'd like to have something like the next 24 hours
- If i create a favourite channel list with DreamboxEdit, if some channel changes frequency there is a way to autoupdate it? Or i've to do a full scan and then manually edit everything again?
Thanks
Dani
Thanks
Dani
