Something missing on the right hand side of 2.1.5
Contact99
Trying to increase my knowledge of the Duo 2 using BH 2.1.5.
On the Right hand side of the Main Menu, Blackhole settings, Blackhole Green panel and other where the time is on the right top hand side and the channel name is on the right bottom hand side there seems to be something missing example in Blackhole settings there is two gears etc, now can anything else be put in that spot.
Thanks
Thanks
" Blackhole settings there is two gears etc"
No,
It happened because we have more panels than before
and should be changed in image coding.
Black hole Green panel
use plugins ico if available.
e.t.c
No,
e.t.c
Thank you
Once again I've been educated by you guys.
