Sony UWA-BR100 driver possible?
scart
Hi.
I just bought a Solo2 box and found a wifi dongle at home but it only works for the TV at this moment. I found a way to make it work on linux but I have no experience i vu+ or much in linux. There are drivers that work HERE . Would be great if I could get direction to how I insert the drivers into my box.
Hi.
This device uses Atheros chipset & chip and the linux support is already included into BH images.
Yes sorry I noticed that but I am unable to use it for some reason. It is not listed under devices manager, and I cannot set up a wireless connection through network setup. When I try to start Wireless Access point plugin I get the error message "Wireless lan device is not detected".
If the device is correctly detected, you can use "WirelessLanSetup" plugin (Into System Menu) to configure your wireless network.
In other cases, your device is not detected correctly and needs some works to be operative.
Well it seems like it is detecting it:
T: Bus=04 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 4 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=ff(vend.) Sub=ff Prot=ff MxPS=64 #Cfgs= 1
P: Vendor=0411 ProdID=017f Rev= 2.02
S: Manufacturer=BUFFALO
S: Product=(CEWL 1)
S: SerialNumber=12345
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=500mA
I:* If#= 0 Alt= 0 #EPs= 6 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=83(I) Atr=03(Int.) MxPS= 64 Ivl=125us
E: Ad=04(O) Atr=03(Int.) MxPS= 64 Ivl=125us
E: Ad=05(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=06(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I know that is the device because it was called CEWL 1 when I tried connecting it to my laptop. Yet the plugin WirelessLanSetup is not showing up. Any advice?
Thanks for your output I will investigate about it!
Update: I think your device is not yet listed into drivers sources. I will try to add it ASAP.
Update #2: I verified with Google and your device should be supported natively from kernel 3.2.0. With your Solo2 there is newest kernel 3.3.6... I will check sources....
For debugging purposes only, I need also the output of "dmesg" command when the box end the boot process.
Linux version 3.3.6-1.2 (amedeo@localhost.localdomain) (gcc version 4.4.3 (GCC) ) #1 SMP Tue Dec 18 09:58:56 CET 2012
Fetching vars from bootloader... found 15 vars.
Options: moca=0 sata=1 pcie=0 usb=1
Using 1024 MB + 0 MB RAM (from CFE)
bootconsole [early0] enabled
CPU revision is: 00025a11 (Brcm4380)
FPU revision is: 00130001
Determined physical RAM map:
memory: 10000000 @ 00000000 (usable)
memory: 30000000 @ 20000000 (usable)
bmem: adding 57 MB LINUX region at 6 MB (0x0391e000@0x006e2000)
bmem: adding 192 MB RESERVED region at 64 MB (0x0c000000@0x04000000)
bmem: adding 256 MB RESERVED region at 512 MB (0x10000000@0x20000000)
bmem: adding 512 MB LINUX region at 768 MB (0x20000000@0x30000000)
Zone PFN ranges:
Normal 0x00000000 -> 0x00050000
Movable zone start PFN for each node
Early memory PFN ranges
0: 0x00000000 -> 0x00010000
0: 0x00020000 -> 0x00050000
On node 0 totalpages: 262144
free_area_init_node: node 0, pgdat 80692880, node_mem_map 81000000
Normal zone: 2560 pages used for memmap
Normal zone: 0 pages reserved
Normal zone: 259584 pages, LIFO batch:31
PERCPU: Embedded 7 pages/cpu @81a09000 s5632 r8192 d14848 u32768
pcpu-alloc: s5632 r8192 d14848 u32768 alloc=8*4096
pcpu-alloc: [0] 0 [0] 1
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 259584
Kernel command line: ubiroot rootflags=sync bmem=192M@64M bmem=256M@512M ubi.mtd=rootfs rootfstype=ubifs root=ubi0:rootfs
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Primary instruction cache 32kB, physically tagged, 4-way, linesize 64 bytes.
Primary data cache 32kB, 4-way, linesize 32 bytes.
MIPS secondary cache 256kB, 8-way, linesize 128 bytes.
Memory: 571648k/1048576k available (5607k kernel code, 476928k reserved, 1125k data, 188k init, 0k highmem)
Hierarchical RCU implementation.
NR_IRQS:160
Measuring MIPS counter frequency...
Detected MIPS clock frequency: 1305 MHz (163.137 MHz counter)
Calibrating delay loop... 869.37 BogoMIPS (lpj=434688)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
bcm40nm_pm_moca_disable 00
SMP: Booting CPU1...
SMP: CPU1 is running
Brought up 2 CPUs
devtmpfs: initialized
NET: Registered protocol family 16
USB0: power enable is active high; overcurrent is active low
USB1: power enable is active high; overcurrent is active low
bio: create slab <bio-0> at 0
SCSI subsystem initialized
libata version 3.00 loaded.
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Advanced Linux Sound Architecture Driver Version 1.0.24.
cfg80211: Calling CRDA to update world regulatory domain
Switching to clocksource wktmr
NET: Registered protocol family 2
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Registering unionfs 2.5.11 (for 3.3.0-rc3)
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
NTFS driver 2.1.30 [Flags: R/W].
msgmni has been set to 1116
io scheduler noop registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x10406900 (irq = 65) is a 16550A
console [ttyS0] enabled, bootconsole disabled
serial8250.0: ttyS1 at MMIO 0x10406940 (irq = 66) is a 16550A
serial8250.0: ttyS2 at MMIO 0x10406980 (irq = 67) is a 16550A
loop: module loaded
__clk_enable: sata [1]
bcm40nm_pm_sata_enable 00
ahci: SSS flag set, parallel bus scan disabled
ahci strict-ahci.0: AHCI 0001.0300 32 slots 2 ports 6 Gbps 0x3 impl platform mode
ahci strict-ahci.0: flags: ncq sntf stag clo slum part
scsi0 : ahci_platform
scsi1 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x10181000-0x10190fff] port 0x100 irq 41
ata2: SATA max UDMA/133 mmio [mem 0x10181000-0x10190fff] port 0x180 irq 41
brcmstb_nand: NAND controller driver is loaded
__clk_enable: network [1]
__clk_enable: enet [1]
bcm40nm_pm_genet_enable 00
Found PHY at Address 3
Config GPHY through MDIO
__clk_disable: enet [0]
bcm40nm_pm_genet_disable 00
__clk_disable: network [0]
__clk_enable: moca_genet [1]
bcm40nm_pm_genet1_enable 00
__clk_enable: moca [1]
bcm40nm_pm_moca_enable 00
ata1: SATA link down (SStatus 0 SControl 300)
ata2: SATA link down (SStatus 0 SControl 300)
No PHY detected, not registering interface:1
__clk_disable: moca [0]
__clk_disable: moca_genet [0]
bcm40nm_pm_genet1_disable 00
bcmgenet: probe of bcmgenet.1 failed with error -5
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
__clk_enable: usb [1]
bcm40nm_pm_usb_enable 00
ehci-brcm ehci-brcm.0: Broadcom STB EHCI
ehci-brcm ehci-brcm.0: new USB bus registered, assigned bus number 1
ehci-brcm ehci-brcm.0: irq 69, io mem 0x10480300
ehci-brcm ehci-brcm.0: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ehci-brcm ehci-brcm.1: Broadcom STB EHCI
ehci-brcm ehci-brcm.1: new USB bus registered, assigned bus number 2
ehci-brcm ehci-brcm.1: irq 70, io mem 0x10480500
ehci-brcm ehci-brcm.1: USB 0.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
ehci-brcm ehci-brcm.2: Broadcom STB EHCI
ehci-brcm ehci-brcm.2: new USB bus registered, assigned bus number 3
ehci-brcm ehci-brcm.2: irq 74, io mem 0x10490300
ehci-brcm ehci-brcm.2: USB 0.0 started, EHCI 1.00
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
ehci-brcm ehci-brcm.3: Broadcom STB EHCI
ehci-brcm ehci-brcm.3: new USB bus registered, assigned bus number 4
ehci-brcm ehci-brcm.3: irq 75, io mem 0x10490500
ehci-brcm ehci-brcm.3: USB 0.0 started, EHCI 1.00
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 1 port detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-brcm ohci-brcm.0: Broadcom STB OHCI
ohci-brcm ohci-brcm.0: new USB bus registered, assigned bus number 5
ohci-brcm ohci-brcm.0: irq 71, io mem 0x10480400
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 1 port detected
ohci-brcm ohci-brcm.1: Broadcom STB OHCI
ohci-brcm ohci-brcm.1: new USB bus registered, assigned bus number 6
ohci-brcm ohci-brcm.1: irq 72, io mem 0x10480600
hub 6-0:1.0: USB hub found
hub 6-0:1.0: 1 port detected
ohci-brcm ohci-brcm.2: Broadcom STB OHCI
ohci-brcm ohci-brcm.2: new USB bus registered, assigned bus number 7
ohci-brcm ohci-brcm.2: irq 76, io mem 0x10490400
hub 7-0:1.0: USB hub found
hub 7-0:1.0: 1 port detected
ohci-brcm ohci-brcm.3: Broadcom STB OHCI
ohci-brcm ohci-brcm.3: new USB bus registered, assigned bus number 8
ohci-brcm ohci-brcm.3: irq 77, io mem 0x10490600
usb 4-1: new high-speed USB device number 2 using ehci-brcm
hub 8-0:1.0: USB hub found
hub 8-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
Success! Registering the characther device success with 0
blackhole initialised
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
ALSA device list:
No soundcards found.
TCP cubic registered
lib80211: common routines for IEEE802.11 drivers
lib80211_crypt: registered algorithm 'NULL'
PM: CP0 COUNT/COMPARE frequency does not depend on divisor
EBI CS0: setting up NAND flash (primary)
NAND device: Manufacturer ID: 0xec, Chip ID: 0xda (Samsung NAND 256MiB 3,3V 8-bit)
brcmnand brcmnand.0: 256MiB total, 128KiB blocks, 2KiB pages, 16B OOB, 8-bit, Hamming ECC
Bad block table found at page 131008, version 0x01
Bad block table found at page 130944, version 0x01
nand_read_bbt: bad block at 0x00000a540000
Creating 4 MTD partitions on "brcmnand.0":
0x000001f00000-0x000010000000 : "rootfs"
0x000001f00000-0x000010000000 : "rootfs(redundant)"
0x000000200000-0x000000900000 : "kernel"
0x000000900000-0x000000a00000 : "mac"
UBI: attaching mtd0 to ubi0
UBI: physical eraseblock size: 131072 bytes (128 KiB)
UBI: logical eraseblock size: 126976 bytes
UBI: smallest flash I/O unit: 2048
UBI: VID header offset: 2048 (aligned 2048)
UBI: data offset: 4096
UBI: max. sequence number: 936
UBI: attached mtd0 to ubi0
UBI: MTD device name: "rootfs"
UBI: MTD device size: 225 MiB
UBI: number of good PEBs: 1795
UBI: number of bad PEBs: 5
UBI: number of corrupted PEBs: 0
UBI: max. allowed volumes: 128
UBI: wear-leveling threshold: 4096
UBI: number of internal volumes: 1
UBI: number of user volumes: 1
UBI: available PEBs: 0
UBI: total number of reserved PEBs: 1795
UBI: number of PEBs reserved for bad PEB handling: 17
UBI: max/mean erase counter: 3/1
UBI: image sequence number: 445573595
UBI: background thread "ubi_bgt0d" started, PID 45
UBIFS: parse sync
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: file system size: 223858688 bytes (218612 KiB, 213 MiB, 1763 LEBs)
UBIFS: journal size: 9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
UBIFS: media format: w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root: 0 bytes (0 KiB)
VFS: Mounted root (ubifs filesystem) on device 0:14.
devtmpfs: mounted
Freeing unused kernel memory: 188k freed
NET: Registered protocol family 10
rtw driver version=v3.4.4_xxxx.20120730
Build at: Dec 18 2012 10:12:22
usbcore: registered new interface driver rtl8192cu
procmk_init
dvb_bcm7356: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
DVB: registering new adapter (vusolo2)
bcm7335: hotplug_callback():
Hotplug - status.connected 1
Hotplug - connecting HDMI to display 0xe
[GP]:brcm_pwm_init
brcm_demux_init: $Id: bcm7335_demux.c,v 0.6 $
[VID]: <6>bcm7335_video_init
[AUD]: <6>bcm7335_audio_init
DVB: registering adapter 0 frontend 0 (BCM7346 FE)...
[MPVR]: >> misc_pvr_init
BKNI_P_GetTrackAllocEntry_resize: resizing from 4096->8192
BKNI_Malloc(linuxkernel) top users:
blocks, bytes, filename:line
694, 33312, portinginterface/vdc/src/common/bvdc_bufferheap_priv.c:737
573, 128676, ../BSEAV/lib/utils/balloc.c:35
539, 21560, ../magnum/basemodules/mem/bmem_system.c:286
365, 43800, magnum/commonutils/mrc/7346/bmrc_monitor.c:940
input: dreambox advanced remote control (native) as /devices/virtual/input/input0
[LCD]: registered
[CI]: registered ci0
[DFP]: registered dbox fp
[DFP]: Scart 9597 is found 4
[SC]: registered sci0
[SC]: registered sci1
system_time_set wakeup mode get
system_time_set wakeup mode get 0xc4
fpga update driver loaded
udevd (105): /proc/105/oom_adj is deprecated, please use /proc/105/oom_score_adj instead.
usb 4-1: ath9k_htc: Firmware - htc_7010.fw not found
ath9k_htc: probe of 4-1:1.0 failed with error -22
usbcore: registered new interface driver ath9k_htc
[VID]: VIDEO_SET_STREAMTYPE 0
[VID]: VIDEO_SELECT_SOURCE 1
[VID]: VIDEO_PLAY 1 2 0
[VID]: VIDEO_CONTINUE 1 1
[VID]: VIDEO_CLEAR_BUFFER 1 1 0
[VID]: VIDEO_STOP 0 1
[VID]: VIDEO_SELECT_SOURCE 0
ADDRCONF(NETDEV_UP): eth0: link is not ready
eth0: Link up, 100 Mbps Full Duplex
ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Hotplug - status.connected 0
Hotplug - Disconnecting HDMI from display
[LCD]: unknown cmd 0x1015
[CI]: CI interface initialised
eth0: no IPv6 routers present
[AUD]: AUDIO_SET_MUTE 0
[AUD]: AUDIO_SET_MIXER -854336016
[AUD]: AUDIO_SET_MIXER : amixl 0, amixr 0
[AUD]: AUDIO_SET_MIXER : next left volume 0, right volume 0
[AUD]: AUDIO_SET_MIXER : next left volume -70, right volume -70
Here is the dmesg. I guess the bold part is where the problems are.
