Sound but no picture
Hally101
Hi all
Have a little problem with my Duo that I cannot understand and would appreciate any help or pointers. On the Setanta Sports channel the sound is fine but I have no picture clearing does anyone have any idea about this at all?
TIA
I don't think the problem is with the Duo as I am able to view this channel.
I suspect you have problems with the configuration of other files that we can not discuss here.
I am sure if you look you will find the help you need elsewhere.
Just sorted it by deleting the service using Dbedit and then recreating a new one with the same details, very odd indeed.
Odd indeed as I already did that and it didn't work for me! What I have noticed now and even more strange is that if I use Picture in Picture for that channel the picture appears in the small box but as soon as I make it full screen again the picture goes black. What are the PIDS you are currently using that have it working please copy them from DBedit for me and post them if you would be so kind.
Thanks
I just had this issue today.
In my case I found that It was a Pids issue.
Vid and Audio are both on 2333 and should be
Vid 2333
Audio 2332
You can manual edit in Dreambox Edit and transfer back to Vu Duo.
However a restart or a complete reboot does nothing and you will still get a black screen.
The only way I could get it to work was via restarting Enigma from Dreambox Edit. I sure re-starting GUI on box will have the same effect.
Hope this helps someone
