Splitter: 2 TV's
Vincent2014
Hallo,
I have this Splitter:
https://www.hama.com/00042576/hama-a-120-hdmi-splitter-2-ports
and the resolution 3840x2160 is supported (in manual).
Well, I want to split with my VU+ Ultimo 4k the signal to another TV (HD not 4k): when the resolution in VU+ is 1080i no problems but if I wish to watch a 4k signal and I change to 3840x2160 any signal in LG UHD TV.
When I remove the cable to HD TV is working.
Why? Any other solutions?
Thanks for your reply.
Regards!
Hallo,
Regards!
How can you split 2 different resoutions with the same cable?
Iif you try FULL HD ... it will work, surely.
The problem is that your 2nd TV desn´t supports 4k resolution.
Though, you have to set your STB output to 1080p mode and not 2160p, and use on both TV sets the same resolution ( 1080p ).
