SplitThisList!
shax
Vip
Description
This application will allow you to simply edit Enigma1 & Enigma2 services with only few clicks. You load the list, choose satellites you want and you're done. All unselected satellites, empty bouquets and markers are automatically removed from the list. Delimiters (lines used to visually divide bouquets) specified in the application will be preserved even when empty.
Requirements
* Windows XP or higher
* Windows Installer 3.1
* .NET Framework 3.5
* 20 MB of free disk space
Features
* supports Enigma1 & Enigma2 services (automatic detection)
* tasks support (add,modify and delete custom tasks to process things you do often automatically)
* direct split (load the list, choose satellites you want and load them directly, no need to define any tasks)
* box profiles (settings for multiple receivers)
* automatic settings checker (Address and ports turns green if connection is possible)
* direct box download (loads settings directly from the receiver
* direct box upload (direct split)
* loading settings from compressed archive ZIP & RAR (searches archive automatically for settings)
* local file support (loads services from the disk)
* full background processing and multithreading support
* variable file names based on currently loaded settings type and current date (%E in file name is replaced by E1 or E2, %d is replaced by current date)
* ZIP output (if checked, result of the task will be compressed ZIP archive)
* custom delimiters definition (choose what bouquets will be preserved even if empty)
* multilingual support
* option to move Eutelsat W2 position in the list from 15.8 to 16E if wanted
* autoupdate of the application when new version is available
Translation
To translate application to a new language
* go to your Documents folder
* go to Krkadoni\SplitThisList\Languages sub folder
* choose language you want to translate from (for example english.txt) and copy it to a new file in the same folder (for example deutsch.txt)
* open the file
* everything in the square brackets [ ] should not be touched
* everything on the left of the = should not be touched
* everything on the right of the = should be translated
* translations should not have leading or trailing spaces
* file has to be in ANSI formatting (not UTF-8 or Unicode)
In the [Language] section enter the information, for example
[Language]
Name=Deutsch
Author=Your Name
DateModified=01.01.2011
When you start application new language will be available for selection in program settings.
Once you're done send us the file to include it in future releases.
Thanx Shax,,,I've Dload and going to tested,,,,had tried other setting editors,,,and they are not friendly user!
Will see about this one!!!!!
Thanx again for your effort!
a911
This is not typical settings editor, as a mather of fact, it doesn't actually edit anything, it just cleans and trims your settings from unwanted satellites.
Ok fine, will discussed more @SplitThisList-support forum, which am a member there!
or U can tell us what U mean by it just cleans and trims your settings from unwanted satellites,,,,
New version is available for download on the same link
Changes in 0.0.8
  • added German language translation (thnx to @muzzos & @Sportfan )
  • fixed parsing errors and various bugs
  • fixed FTP listing errors
  • added support for active FTP connections (auto detection)
  • cleanup of temporary files & folder after running tasks and downloading from box
  • changed default path of task output to “Deskop\SplitThisList” for people having UAC forbidding them to write to disk root.
  • changed icon
New version 0.0.9 is available for download
Changes in 0.0.9
- added Polish language translation (thnx to @kosmacz )
- added video tutorial link
- added support forum link
New version will be offered to update automatically to current users after first program restart.
