SSH and SFTP on BH
badanas
Hi
Where is the setting to activate SFTP on my VU+ Uno ? If i desactivate telnet i can connect via SSH with putty, but cant connect with winscp.
My objective is connect ( telnet + sftp ) using port 22, like i am doing in my other box. In casual enigma 2 box is only activate ssh daemon and is ready.
Thanks
Hi
Thanks
Into WinSCP you should select SCP protocol instead of SFTP ....
Yes, WinSCP works fine using SCP - but, according to this (and initial impressions as well), resume is not possible. This is big disadvantage, where large recording files are concerned.
Has anyone managed to get WinSCP running to a Vu box (BH 3.0.2) using SFTP, rather than SCP?
