Stab HH120 is slow
Rotation Speed 0.7°/s (18 V); 0.4°/s (13 V)
Stab HH100
Rotation Speed 1.8°/s (18 V); 1.2°/s (13 V)
Stab HH90
Rotation Speed 2.4°/s (18 V); 1.5°/s (13 V)
It is a slow motor overall when compared to others, even with Stab (HH100 and HH90).
Then you have tricks when you switch from distant satellites, make the change in a horizontal polarity channel (18 volts), run more.
If you have assumed it is slow, it is not a problem.
I have the old SG2100 and clones (Dimo120/Dimo120+), very happy with their slowness and they are faster.
In Spanish for me.
Es un motor lento en general si comparas con otros, incluso con Stab (HH100 and HH90).
Luego tienes trucos cuando cambias de satelites alejados, realizar el cambio en un canal de polaridad horizontal (18Voltios), corre mas.
Si tienes asumido que es lento, no es problema.
Tengo los viejos SG2100 y clones (Dimo120/Dimo120+), muy contento con su lentitud y son mas rapidos.
En español para mi.
