Kodi is a plugin, that you can use on later VU+ models, with sufficient power. I'm unsure of the statistics, regarding the VU+ Solo SE, but if it's powerful enough you should have had the option of installing Kodi during installation.
With Kodi you can watch quite a lot, including films, and television services, by streaming, using fast internet, but if you wish you can set up a record path, media/hdd/movies, in the options, then instead of viewing you can download it, to your hard drive, and view it whenever you want, as you have effectively recorded the program, but by downloading it, as you do using the internet.
