standby mode problem
hvdcgkl
Hi,
I've a DUO VU+
i've just installed the 2.02 rev A version
Now when i put my VU+ duo in standby with the remote, after a time it turns off ...
is there a solution to set my VU+ duo to stay in standby mode ?
Thanks really
Hi,
I've a DUO VU+
Thanks really
Have you checked settings in AutoShutdown settings/setup panel in System Menu ??
Ok thanks
i've desactivated "autoshutdown" and "enable action after inactivity"
hope this will the solution.
