Start afresh
fesoj
Heya all
I have the latest image 2.1.5 on my vu duo2. My question is what files do I need to remove so that I will have a clean start as regards the XBMC.
I reflashed my Receiver a couple of times but found that the xbmc which I had previously tested, did not start afresh but kept all settings from first test image.
Would removing these folders (xbmc and .xbmc) be enough
Thank you
Jf
Heya all
Thank you
Jf
Remove ( erase /delete ) only /.xbmc folder certainly located on your HDD root.
Do it with ftp program ( dreambox control center for ex... ) or filezilla.
Best regards
