I am new to this box so I bought it with latest BH image installed. It was running OK for 3 days but today I downloaded a software upgrade to the EPG. This downloaded and and it asked me to restart the box , I said yes and box started to shutdown. When it had not shutdown after 5 mins I swtched off power switch at the back. On turning back on startup routine began until it got to "starting GUI" and just hangs there. I have tried restarting several times but the outcome is the same. Any and all help would be great.
Thanks
Potterson
Should have said box is VU+ DUO
Thanks
Potterson
