Request STB encountered a sofware pb
balpha211
Hi
* I tried to upgrade the firmware for my Vu+ solo yesterday and since then I got a green screen with message "STB encountered a software pb and needs to be restarted".
It restarts but everytime i use my remote to change channel I got the green screen again
* More than that I have no sound and my time system indicates 1970
* No way to use the usb port to flash again my box, it restarts on the resident soware
Copy of my crash log
OpenPLi Enigma2 crash log
crashdate=jeu. janv. 1 01:47:46 1970
compiledate=May 13 2019
skin=PLi-FullNightHD/skin.xml
sourcedate=2019-05-12
branch=release-7.0
rev=37cae09
component=Enigma2
stbmodel=zero
stbmodel=dm8000
kernelcmdline=ubiroot rootflags=sync bmem=192M@64M ubi.mtd=rootfs rootfstype=ubifs root=ubi0:rootfs libata.force=1:1.5Gbps
nimsockets=NIM Socket 0:
imageissue=openpli 7.0-release %h
File "/usr/lib/enigma2/python/Components/PluginComponent.py", line 52, in readPluginList
File "/usr/lib/enigma2/python/Tools/Import.py", line 2, in my_import
File "/usr/lib/enigma2/python/Plugins/Extensions/GraphMultiEPG/plugin.py", line 2, in <module>
from GraphMultiEpg import GraphMultiEPG
File "/usr/lib/enigma2/python/Plugins/Extensions/GraphMultiEPG/GraphMultiEpg.py", line 32, in <module>
from enigma import eEPGCache, eListbox, gFont, eListboxPythonMultiContent, RT_HALIGN_LEFT, RT_HALIGN_RIGHT, RT_HALIGN_CENTER, RT_VALIGN_CENTER, RT_WRAP, BT_SCALE, BT_KEEP_ASPECT_RATIO, BT_ALIGN_CENTER, eSize, eRect, eTimer, loadPNG, eServiceReference
ImportError: cannot import name BT_ALIGN_CENTER
File "/usr/lib/enigma2/python/Plugins/SystemPlugins/SoftwareManager/plugin.py", line 10, in <module>
from Screens.Opkg import Opkg
ImportError: No module named Opkg
REMOVE Peer vuzero
REMOVE Peer vuzero
File "/usr/lib/enigma2/python/Screens/Hotkey.py", line 527, in action
File "/usr/lib/enigma2/python/Screens/Hotkey.py", line 566, in hotkeyGlobal
File "/usr/lib/enigma2/python/Screens/Hotkey.py", line 551, in getKeyFunctions
File "/usr/lib/enigma2/python/Screens/Hotkey.py", line 192, in getHotkeyFunctions
File "/usr/lib/enigma2/python/Components/PluginComponent.py", line 133, in getPluginsForMenu
File "/usr/lib/enigma2/python/Plugins/SystemPlugins/FastScan/plugin.py", line 400, in FastScanStart
if menuid == "scan" and getProviderList():
File "/usr/lib/enigma2/python/Plugins/SystemPlugins/FastScan/plugin.py", line 60, in getProviderList
return [x[0] for x in providers if nimmanager.getNimListForSat(transponders[x[1][0]][3])]
AttributeError: NimManager instance has no attribute 'getNimListForSat'
dmesg
<4>[VID]: VIDEO_SELECT_SOURCE 1 0
<4>[VID]: VIDEO_FREEZE 1 0
<4>[AUD]: AUDIO_SELECT_SOURCE 1
<4>[AUD]: AUDIO_PAUSE 1
<4>[VID]: VIDEO_SET_STREAMTYPE 1
<4>[VID]: VIDEO_PLAY 1 5 2
<4>[AUD]: AUDIO_SET_BYPASS_MODE 11
<4>[AUD]: AUDIO_SET_BYPASS_MODE Stopping decoder
<4>[AUD]: AUDIO_CONTINUE 5 2 aph=0x0
<4>[AUD]: AAC downmix 0 state : 0
<4>[AUD]: AUDIO_SET_BYPASS_MODE ReStart decoder
<4>[AUD]: AUDIO_PLAY 11 decoder start : 1
<4>[AUD]: AUDIO_PLAY Stopping decoder
<4>[AUD]: AUDIO_PLAY : Starting Playpump
<4>[VID]: VIDEO_CONTINUE 5 1
<4>[VID]: VIDEO_SELECT_SOURCE 1 1
<4>[VID]: VIDEO_PLAY 1 5 0
<4>[VID]: VIDEO_CONTINUE 1 1
<4>[VID]: VIDEO_CLEAR_BUFFER 1 1 0
<4>[VID]: VIDEO_STOP 0 1
<4>[VID]: VIDEO_SELECT_SOURCE 0 0
<3>[LCD]: unknown cmd 0x1015
<3>UBI error: ubi_open_volume: cannot open device 0, volume 0, error -16
<4>[AUD]: AUDIO_SET_MUTE 0
<4>[AUD]: AUDIO_SET_MIXER -1392099856
<4>[AUD]: AUDIO_SET_MIXER : amixl 0, amixr 0
<4>[AUD]: AUDIO_SET_MIXER : next left volume -570, right volume -570
<4>[AUD]: AUDIO_SET_MIXER : next left volume -70, right volume -70
<4>[AUD]: AUDIO_SET_MIXER : amixl 7, amixr 7
Thanks for any help
AGAIN? Again this question? Not only you did not consider @Shiro's answer, because this is NOT OpenPLI forum but, instead, BlackHole and OpenBlackHole one, but you are spamming this forum having posted 3 times (so far) the same question (often in wrong sections). Also here
https://www.vuplus-community.net/board/threads/stb-encountered-a-sofware-pb.42894/
and here
and here
https://www.vuplus-community.net/board/threads/stb-encountered-a-sofware-pb.42889/
