Since I updated to 3.1.0 E today the receiver is keep chrashing during Channel zapping and got the following green screen with such information:
unicode U+2582 not present
unicode U+2583 not present
unicode U+2585 not present
unicode U+2586 not present
unicode U+2587 not present
unicode U+2588 not present
After reinstalling with different images, I have found out that after updating with E version , the settings have been messed up, I have deleted all the setting and redone everythings and now it works again.
HI!
I was too quick, the problem is happening again nad exactly the same thing with 2 Different devices (1solo4k se and a duo2) and with different images, BH and VTI.. I^m a bit lost ....
HI!
1.Have you installed any plugin or some add-on ?
2. Have you insert a ready-made Sat list or did you just have make channels Scan ?
3.Have you insert something into the image that is not original within the image ?
Some backup and the like.
No plugin
REady made sat list, but it looks to me that here is the problem, I can zap untill channel 70 then the crash, I can zapp back from the last channel untill near 70 and then crash agai.. channel number that exist (zapping back you will find them) are not existent if you give the number over the RC....very strange...
If you used an old list, even your own, sometimes a channel, or some channels, can cause problems, as the channel has moved transponder, or ceased and been replaced.
You could try running a full scan, selecting the option to clear before scan.
Again a problem with this autosettings... A manual scan is not possible, isn't? A proper, clever organisation in bouquets is so terrible?
You people keep being lazy using these terrible toools and then you have issues.
Use a decoder for what it's its main aim: scanning channels.
