STB software problem
lmeek01
Hi does anyone know what is causing the attached STB software error.
I am running a VU+duo. And have reflashed image a number of times the box seem fine for a day or so the crashes an is in this continues loop.
Thanks
Full flash is required? Is there any guides on how to do this on the forum
No.
If there is no room in a flash then image the same as the PC with full HDD can not function normally.
So check the condition/status of the flash especially if you're adding something in to image after image installation.
You can check with bluebutton>>Yellow>>System Info (Flash space)
No.
Hi Matrix, flash is running at 67% 69mb/103mb
Will be better the full crash log instead of the photo :) You can find it on the root of /media/hdd, if you use HDD attached and mounted
