Step by step ...
Van Malder
Hello everybody,
Step by step I'm discovering the VU+ duo ;;; but still have plenty to learn and some questions based on the BH 1.6.2 image i have put on the machine. One of these is the following: which wifi stick do you recommend me to buy ? where ? amazone ? the idea is to stream on an ipad ... well my wife one (I do not have the possibility to connect a cable :cry:) and I have a wifi bridge (Vonets) for the moment and many difficulties to stream on my PC
Thanks,
Philippe
I use the Netgear WNCE2100. It gives a bit of trouble messing with your IP gateway address on your network, but looks like I've got that sorted and otherwise works fine.
I tried hooking a switch on the back of the WNCE2001 so I could put my TV and Vu+ on it, but I couldn't get it to work so ended up buying another WNCE2001. Now my TV and Vu+ both have one.
