AlexWilMac
Moderator
I've been using CrossEPG for many years and I've always been able to set alias.conf for the cases I need, specifically to copy EPG from SD to HD channels.
The examples at the beginning of alias.conf are simple and easy to follow.
But, lately, I can't get to my goal: copy the EPG from some channels, for instance some RAI channels (but only some, the ones I'll tell later) to the correspondent HD.
This issue affects, among the others: Rai Movie, Rai Premium, Rai News 24 and other ones, but not RAI1, Rai2, Rai3 and others, for whom my alias.conf woks perfectly.
Note that, I want to copy the EPG of the satellite version of the 3 channels above, which is the most complete one, usually about 5 days.
It should be done very easily either by this line
Rai Movie-RAI=Rai Movie HD
or, to be even more sure, by this
2136-3070-013e=Rai Movie HD
or, also,
2136-3070-013e=4536-30D4-013e
just to talk about Rai Movie. Same issue for the others already mentioned.
But there is nothing to do: it just does not work.
Where do I fail? What puzzles me is that this scheme perfectly works for many other channels.
or, also,
