I facing a strange problem with the last BH 2.0.8
At installation I have set my network to DHCP mode and all is working fine.
To avoid to check my ip each time I want to access my vu Duo I have now set it up to static IP using the interface.
All looks OK for a couple of hours but after putting my STB in standby and waking it up next morning I cannot access it using the static IP address.
I check in my router and noticed that my duo had received a new dynamic address from my router DHCP server.
IF I check my setting all is OK in the GUI interface ( setting are static).
I can fully access my duo using the dynamic address and if I check the file /etc/network/interfaces all seems to be configure for a static environment.
Any idea to help me
Thanks for the help
Any idea to help me
Thanks for the help
