Carefully check your antenna settings. If you are using USALS, the motor should move to any available satellite in the arc if everything is adjusted correctly. Make sure USALS is set in antenna settings and verify that the correct latitude and longitude have been entered.
If you are using Diseqc 1.2, then verify that the correct number has been entered for 28,2E in the antenna settings.
I am using USALS and that's why I cannot explain why the motor does not move to 28.2e. I checked satellites.xml and that is fine. Is there any other setting on the box ?
I have BH 1.7.9 because I consider the most stable image for what I do. Now that I think about it is since I changed image that 28.2E does not work....
Now the question is where do we have the motor settings in E2 ?
In my configuration it says Simple Configuration -> Motor
