strangest network problem
yummer
BH Lover
Hi friends.... right i have the strangest network problem.
i have my duo2 connected via ethernet to my router it streams etc to my ps3 etc perfectly the thing is recently it wont connect to the bh server or bh speed up but will connect to bh stats?
Ive checked cable by connecting to laptop... perfect
ive tried internal wifi bh server connects fine!
is this likely a HW fault with my box? i just dont get how i can stream perfectly through my lan via ethernet and not reach the outside world ... i.e the bh server!
weird..... had a look at router config.... changed static ip address and all good now! never had problem before :lamo::chair::wallbash:
problems back when im portforwarding for transcoding etc.... isp may be having a phone call i think.. they've been fiddling the otherday
well isp where a great help.... NOT... (sorry sir we do not support portforwarding....... by trial and error ive found that it looks like my isp are now blocking port 80 since my line migration...so changed port in openwebif config to something else.
If your router has been provided by your ISP, probably port 80 of your public IP address is already used to configure and monitor your router by your ISP and so can't be redirect to an internal virtual server.
it was working before the other day mate... came home yesterday router connection light off... rang them said they where migrating line because it wasnt stable or something (never had a problem) came back on and ever since port 80 was no good for me! changed it all now so great technical support off isp haha :grin:
And the only thing it was blocking was bh addons server...
