Stream authentication
Pal Ryvaenge
Hi, earlier in Enigma there was an option in the Openwebif plugin to choose stream autentication with username and password, this has been gone quite a while.
Problem, my port 8001 is open in my firewall for me to stream away from home, suddenly my box was blinking "recording" and I detected a serbian ip adress streaming from port 8001, detected it with netstat on my solo2.
It would be great if the stream authentication could be implemented again.
I think it's a question for E2OpenPlugins developers because the OpenWebIf project is under the development team.
i have the http authentification on the webinfo (blackhole 2.0.8)+solo 2
I have the http autentification on yes, but that is just for the webif.
Problem is that when port 8001 is open and you know there is a linux tuner behind it you can just add a channel string like "1:0:19:FA3:7D1:2:11A0000:0:0:0:" (Sky Sports 1 HD) and stream from it, like someone did with my box last night.
Example: http://IpAdress:8001/1:0:19:FA3:7D1:2:11A0000:0:0:0:
I`m pretty sure I had a stream authentification in earlier enigma images on my old Abcom Ipbox.
