stream conver channels help
scubidoo
i all
My setup is one vu solo2 and one vu solo.
On vu solo2 i have first tuner 4 sats connect on 1 disecq. Tuner 2 motorised dish polar mount and positioner. All works fine.
Vu solo is connect to vu solo2 using remote channel stream converter.
I can see the import bouquet from solo2 on the solo.
Problem is if a choose one channel on vu solo the motor start to rotate the dish but stops few seconds after and not a the sat position.
I have to change channels in the same satellite until the dish reach the position. After this if I keep on the same sat all work fine but if I choose another sat I have to switch channels on the same sat until the dish reach the position.
Quiet long the post
Any help will be great even I know is a strange configuration
Best regards
