Stream TV Player
valb
HI!
Since updating to the latest BH version on my Solo2 I have been unable to find a single stream that will play. I know that sometimes links can be dead but there are usually some that work. E.g. Abbey Road webcam, Niagra Falls webcam , RT, NASA TV.
One thing I have noted is that under earlier versions the "loading" ikon blinked until the stream had been buffered. Nothing happens when I choose a stream under the current version. All I can do is press stop or exit and confirm that I want to stop playing the stream (that wasn't playing anyway).
Do I have to change any settings to get it to work? This wasn't necessary before.
My web connection is OK as YouTube works fine and I have also been able to disable and then enable Stream TV Player which, according to what it said on the screen. involved a download.
Your help would be much appreciated.
Can somebody do me a little favour and tell me if they can get any streams to play with Stream tv player on their Solo2 with latest BH image 2.0.8.1. This will give me an indication whether it is my setup that is wrong or not.
Thanks in advance.
Valb
Thanks for testing but I'm not sure what you mean.
Do you mean add URL to channel list? The problem here is that the addresses are so long and don't stay on the screen long enough to write them down. Where is the file that contains the stream list? It would be easier to note them down from here.
I can not now give you the exact path
because I'm at work. (i think /usr/lib/enigma2/python/extensions/plugins/stream? / stream.xml file located in the plugin folder and can be edited
with linux editor on PC
The addition of stream channels in the satellite list bouquets,
search at forum
I wrote a couple of times already.
OK! Thanks I'll have a search.
Don't work too hard (at work)! You won't have any energy left to help us lost soles with BH.
Regards
Valb
As an experiment I installed Tsonline and some of the webcams worked in this so I tried Stream TV player again and lots of the programmes and webcams started to work again. It seems that Tsonline has updated something so that Stream TV player works again.
Valb
I'm having trouble getting the streams working in a custom streams.xml
Can someone please advise on how to correct the streams.xml
I have added the .txt extension in order to upload the file
Thankyou in advance
Can someone please advise me how to remove StreamTV plugin? There is an option to remove in the "BH Extensions managment" but it seems to not working :(
