Stream TV RTMP protocol
elec
I have problem with the iptv plugin. I can not connect to any of the ip tv services I can see in the list at all.
Running BH 2.0.4 on my Duo.
Using my computer and the same router connecting to the same iptv service there is no problem.
So there is no router issue I think.
Any help would be very much appreciated.
Hi m8 elec
I had the same problem with my VU+duo. I was not able to even use the plugin like mytube.
After checking I found out it was network problem, check you ip address. If the problem is not solved, I suggest you re-install the image again and see how it goes.
Good Luck
Hi m8 elec
Good Luck
I can download addons using my box so there is no problem with the network I think.
I will reinstall and hope that my problem will be solved.
