Stream TV
Please ,No outside links!
Thank you!
Sorry for that, excuses.
There is also "NStreamplayer" . Info about this you will find on the same Russian forum, check "enigma2 and IPTV" on left top of homepage.
That's all I know, played both on my VU+ Duo but removed them, it's hard to get any good adresses/links that play not Russian/Turk.
V8
By the way, I know that "Dursun55" knows/post a lott about xml files etc etc.
Google "Dursun55" or "Dursun55.xml" etc etc........ and you will find out.
Has anyone tried a stream using authentication with this plugin? Looking at subscribing to
http://mlb.mlb.com/mlb/subscriptions/index.jsp?&c_id=mlb&affiliateId=mlbMENU
Edit by angelofsky1980: no live links please.
@f1ngers,
This is a pay tv station over internet so you cannot take that for free unless you know a "crack"(most unlikely) or someone that want you to take his entry (password etc) to watch this channel.
V8
@f1ngers,
V8
No, I understand that mate. That's why I said "looking at subscribing to". Just wondering if I was to subscribe are there parameters in the plugin for authenication?
Anyone knows how to implement and get working the following Live Tv channel stream on Vu+ Ultimo HD ? :
http://livetvfreein.net/starvijay.html
Hi,
I modified the StreamTV plugin using attached files in order to support more rtmpdump options in xml list and
better connection error handling .
Also added an example xml list (stream syntax has changed) with a lot of streams and associated icons.
I hope it will be useful .
enjoy!
try replacing & with %
I had the same problem uri containing the symbol & crashes the plugin. Does replacing the symbol & with % work for anyone - I will try it in the evening at home and was jsut wondering whether Evo - you had any success? Thanks
Well - if anyone else has this problem, I used the <![CDATA[rtmp://.......]]> and his works.
