Stream vu zero
Hello,
I have a Vu+Zero Rev.2 working well with satellite channels, my issue is in internal stream, some channels I can open in any applications or operating systems, any tips how to solve ?
Best Regards.
You should know what goes on... are codec problems, this is more than spoken!
On PC uses MPC... on smartphone some channels may even be possible for your view.
You can find almost everything about this subject in Drag... It seems that only us, Portuguese who tune Hispasat 30W, is that we have these problems.
Ok p.rodrigues, thanks for your tips.
