Streaming only audio and no picture after a few days.
spaceman
Hi.. can anyone please help me in regards to how I can trouble shoot this? issue is intermittent and only way to resolve is by doing a reboot on the box.
I can stream as normal for a few days.. then after a while it stops working and all i get is a blank screen with audio of the stream.
I have got it set to transcode with the following options -
port: 8002
auto set frame rate: off
bitrate: 01000000
framerate: 25000
resolution: 480p
Solo4k with version 3.0.2.0
I have following logs and can see an internal error of some sort and if anyone can help me debug that would be great -
Oct 29 13:15:28 vusolo4k user.warn kernel: [ 1641.447334] FE tune
Oct 29 13:15:34 vusolo4k user.alert kernel: [ 1647.089504] Unable to handle kernel NULL pointer dereference at virtual address 00000038
Oct 29 13:15:34 vusolo4k user.alert kernel: [ 1647.097714] pgd = ca295880
Oct 29 13:15:34 vusolo4k user.alert kernel: [ 1647.100430] [00000038] *pgd=0b896003, *pmd=0a261003, *pte=00000000
Oct 29 13:15:34 vusolo4k user.emerg kernel: [ 1647.106826] Internal error: Oops: 207 [#1] SMP ARM
Oct 29 13:15:34 vusolo4k user.warn kernel: [ 1647.111624] Modules linked in: fuse ipv6 brcmfb(O) dvb_bcm7376(PO) dvb_base(PO) bcm_event(PO) procmk(O) ext2 rt5370sta(O)
Oct 29 13:15:34 vusolo4k user.warn kernel: [ 1647.122722] CPU: 0 PID: 2908 Comm: transtreamproxy Tainted: P O 3.14.28-1.8 #1
Oct 29 13:15:34 vusolo4k user.warn kernel: [ 1647.130821] task: ce32a4c0 ti: cccc4000 task.ti: cccc4000
Oct 29 13:15:34 vusolo4k user.warn kernel: [ 1647.136505] PC is at NEXUS_AudioEncoder_AddInput_impl+0x18/0x68 [dvb_base]
Oct 29 13:15:34 vusolo4k user.warn kernel: [ 1647.143679] LR is at NEXUS_AudioEncoder_AddInput+0x3c/0x60 [dvb_base]
Oct 29 13:15:34 vusolo4k user.warn kernel: [ 1647.150128] pc : [<bf178a44>] lr : [<bf18666c>] psr: a00f0013
Oct 29 13:15:34 vusolo4k user.warn kernel: [ 1647.150128] sp : cccc5ae8 ip : 00000000 fp : cccc5cec
Oct 29 13:15:34 vusolo4k user.warn kernel: [ 1647.161617] r10: 0000019b r9 : d31de000 r8 : 00000000
Oct 29 13:15:34 vusolo4k user.warn kernel: [ 1647.166847] r7 : 00000002 r6 : 00000000 r5 : caacfd44 r4 : caacfd44
Oct 29 13:15:34 vusolo4k user.warn kernel: [ 1647.173380] r3 : caaa8030 r2 : cb382544 r1 : caacfd44 r0 : 00000000
Oct 29 13:15:34 vusolo4k user.warn kernel: [ 1647.179916] Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
Oct 29 13:15:34 vusolo4k user.warn kernel: [ 1647.187059] Control: 30c5387d Table: 0a295880 DAC: fffffffd
Oct 29 13:15:34 vusolo4k user.emerg kernel: [ 1647.192811] Process transtreamproxy (pid: 2908, stack limit = 0xcccc4238)
Oct 29 13:15:34 vusolo4k user.emerg kernel: [ 1647.199606] Stack: (0xcccc5ae8 to 0xcccc6000)
Oct 29 13:15:34 vusolo4k user.emerg kernel: [ 1647.203968] 5ae0: bf53c3c8 caacfd44 00000000 bf18666c bf9f7584 bf84ab68
Oct 29 13:15:34 vusolo4k user.emerg kernel: [ 1647.212154] 5b00: bf9f6cd4 bf82dc30 00000000 00000000 00000000 cccc5cac cccc5cec 00000000
Oct 29 13:15:34 vusolo4k user.emerg kernel: [ 1647.220340] 5b20: bf9f6cd4 cccc5d2c cc8a6c00 bf8704dc 00000000 00000000 bf9f6cd4 bf86e4dc
Oct 29 13:15:34 vusolo4k user.emerg kernel: [ 1647.523216] 5fc0: 0002f5bc 00031460 00000064 00000036 0002f5bc 00001388 0000138a 00000000
Oct 29 13:15:34 vusolo4k user.emerg kernel: [ 1647.531402] 5fe0: 0002f350 beec9a4c 00017760 b6db4b8c 200e0010 00000006 4f7fd142 59e68b6f
Oct 29 13:15:34 vusolo4k user.warn kernel: [ 1647.540322] [<bf178a44>] (NEXUS_AudioEncoder_AddInput_impl [dvb_base]) from [<bf18666c>] (NEXUS_AudioEncoder_AddInput+0x3c/0x60 [dvb_base])
Oct 29 13:15:34 vusolo4k user.warn kernel: [ 1647.553119] [<bf18666c>] (NEXUS_AudioEncoder_AddInput [dvb_base]) from [<bf82dc30>] (ts_enc_read+0x618/0x1654 [dvb_bcm7376])
Oct 29 13:15:34 vusolo4k user.warn kernel: [ 1647.564382] [<bf82dc30>] (ts_enc_read [dvb_bcm7376]) from [<bf82f1d4>] (ts_enc_ioctl+0x1e0/0x224 [dvb_bcm7376])
Oct 29 13:15:34 vusolo4k user.warn kernel: [ 1647.574506] [<bf82f1d4>] (ts_enc_ioctl [dvb_bcm7376]) from [<c00dd9bc>] (do_vfs_ioctl+0x3e8/0x5a8)
Oct 29 13:15:34 vusolo4k user.warn kernel: [ 1647.583480] [<c00dd9bc>] (do_vfs_ioctl) from [<c00ddbb0>] (SyS_ioctl+0x34/0x5c)
Oct 29 13:15:34 vusolo4k user.warn kernel: [ 1647.590805] [<c00ddbb0>] (SyS_ioctl) from [<c000f060>] (ret_fast_syscall+0x0/0x30)
Oct 29 13:15:34 vusolo4k user.emerg kernel: [ 1647.598386] Code: 0a00000f e92d4070 e1a06000 e1a04001 (e5900038)
Oct 29 13:15:34 vusolo4k user.warn kernel: [ 1647.604583] ---[ end trace 5ad50ce5d246d5e0 ]---
Seems there are some problems with TranStreamProxy and your box but I don't know why. I never used Transcoding with my Solo4K.
